Steering/ABS light
2007 VAUXHALL MERIVA
72,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
DEBBIE WATSON
ABS and engine management light come on. had a diagnostic test done which come up with ABS ring issue. so far I've had the outer CV joint with ABS ring changed but the warning light still on is this meant be turned of or does it turn itself of. The main issue is the EPS light come on but not been picked up on diagnostics tool then the light turns of and drives fine. The steering feels like it shaking when turning at low speed and when turn engine of then back on issue seems to be gone.
Feb 23, 2019 at 6:59 AM
  • 55,214 POSTS
I don't think you need to clear the ABS codes it should go out when the problem is fixed. I have seen the front hubs go out causing this sensor not to work right. What code number is it and what all did they replace?
This video will show how to get the codes:
https://youtu.be/rTtAnsOlZU4
Please run down this guide and report back. Please make a new post for the camshaft sensor issue.
Feb 25, 2019 at 4:59 AM
