Steam coming from under hood
35,000 MILES
MKAV999
After driving steam comes from under hood. Has been happening for a while.
May 15, 2020 at 12:33 AM
This is one of two things most likely. One, either the engine is overheating and the coolant is boiling over and the steam is the coolant burning off the hot engine. The second is you have a coolant leak somewhere and when it gets hot, the coolant is getting burned off and it steams off.
Either way, we need to start with checking the coolant and make sure it is not low. If it is we need to top it off. Second does the temp gauge show the engine is hot or does it actually overheat?
https://www.2carpros.com/articles/symptoms-of-an-overheating-engine
The way we need to find this is to pressure test the cooling system. Here is a guide that will help with that:
https://www.2carpros.com/articles/radiator-pressure-test
Let me know what you find and we can go from there. Thanks
May 15, 2020 at 12:41 AM
