Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Vauxhall
Astra
Engine
Starter
Bolt
Starter motor
2004 VAUXHALL ASTRA
60,000 MILES • 1.7L • 4 CYL • TURBO • 2WD • MANUAL
MILTZ80
MEMBER
1 POST
FOLLOW
When changing the starter motor unable to locate the top bolt? Not sure if the bolt is located on opposite side to the lower bolt.
Aug 19, 2017 at 8:18 AM
SATURNTECH9
CERTIFIED EXPERT
You do not have the new starter to compare where the bolt hole is?
Aug 19, 2017 at 10:37 AM
