After a full gasket replacement, including head gaskets, we have the engine back together and started. It immediately revs to 4,000 RPMs and stays there until we turn it off. The spark plugs are new, the MAP sensor is new, the EGR valve is new, and the oil was replaced. The MAF has been cleaned, and tests the correct voltage, the TPS test for the correct voltage, and the IAC valve was cleaned and visually verified as working. The dealership said we don't need to update the PCM. We have codes p068, which is non-correlation between TPS, MAP, and MAF, but they all seem to be okay. We also have p0123, which is high voltage output from TPS. That specifically tested at .9V before startup and went to 3.6V when I manually opened the throttle with engine running. Hope you have some ideas, and thanks in advance!
Sep 13, 2023 at 12:43 PM
