Engine Starting Trouble
20 MILES • 1.5L • 3 CYL • TURBO • FWD • MANUAL
RANJIT NEOG
I have repaired my accent crdi viva for long starting trouble at a authorized service center. they have replaced piston ring,engine valve,diesel filter now the problem is that engine starts and stop not steady at idle,again they cleaned fuel injector,high pressure pump,fuel tank with motor,and checked rail pressure sensor. ckp sensor but the problem is same ,they are not able to find the cause, so help me someone.
Jun 17, 2016 at 3:26 AM
  • 55,781 POSTS
I would start with a compression test across all cylinders to see how even they are, please get back to me with the readings, here is a guide that with help you.
Let me know what you find
Best, Ken
Jun 18, 2016 at 3:52 PM
