Why will the engine not crank after replacing the passenger side cylinder head?
20,000 MILES • 3.7L • V6 • 4WD • AUTOMATIC
DMARTINEZ49
I replaced the cylinder head on the passenger side and did all the basics and it won’t crank over.
Aug 13, 2022 at 4:54 AM
  • 55,732 POSTS
The first thing i would do is use a beaker bar on the front of the engine at the balancer bolt to see if the engine can be rotated by hand. You might have a bolt in a cylinder which will not allow the engine to turn over.
This guide can help as well:
Can you hear anything when you crank it over? Can you please shoot a quick video with your phone so I can hear the noise? That way I can tell for sure what's going on. You can upload it here with your response.
Aug 14, 2022 at 10:21 AM
