Engine shut off while running, losing compression in three cylinders
2005 KIA CARNIVAL
363 MILES • 2.5L • 6 CYL • AUTOMATIC
LIISASMITH1964
Having problems with my car. It was running and then cut out and now losing compression in three cylinders.
Jun 16, 2018 at 8:57 PM
KHLOW2008
  • 41,814 POSTS
There are many possible reasons for losing compression of the cylinders and if they are on the same bank, a skipped timing belt is the most likely cause.
Check the timing belt condition and verify if the marks are aligned correctly.
The other possible cause is overheating resulting in a bad gasket. This engine is notorious for failed head gaskets and coolant getting to the cylinders.
Have the above checked first.
Jun 17, 2018 at 11:36 PM
