Starting power
164,000 MILES • 6 CYL • AUTOMATIC
ADAMB1995
I put a new battery in the car it came on for like a day or two then went back to not working, but when it was on my driver windows does not come down and it will click but will not turnover. My red oil light is on and brakes.
Jul 9, 2018 at 3:19 PM
  • 110,251 POSTS
Everything you described sounds like a dead battery or weak battery. If the battery worked when it was installed, something tells me the alternator is not working.
I am going to provide a couple links. The first one discusses how to check a battery. The second one discusses how to check an alternator. It is a very simple task. You will need a volt meter. I will attach a link on how to use one.
Do this first. If you determine the alternator, let me know and I will get the directions for replacement.
One last thought, check to make sure the battery terminals are clean and tight. Here are directions:
If you feel uncomfortable checking the battery, remove it and take it to a parts store and they will load test it for you. Most places will do it for free.
Let me know what you find or have other questions.
Jul 10, 2018 at 12:34 PM
