Starting in third gear
104,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
TELFER88
Hi, this is a general question about manual transmission cars and the relationship between rpm and the rod bearings specifically.
If a manual car accidentally takes off from a stop in third gear instead of first gear I understand this will cause extra wear on the clutch, but will it damage the rod bearings?
Two techs I have asked say 'no' and that rod bearings are almost always damaged by lack of oil or contaminated oil.
Your thoughts? Thanks in advance!
Sep 2, 2017 at 11:12 PM
WRENCHTECH
  • 20,760 POSTS
As you were advised at the other site, the advice you have been given is correct.
Sep 3, 2017 at 1:10 AM
HARRY P
  • 2,292 POSTS
That is correct. Starting in third gear is not going to do any damage to the engine or transmission, just the clutch.
Sep 3, 2017 at 7:18 AM
