I bought the truck from a guy that put the starter on himself. the truck cranked right up and he drove it around the block. it started running funny he described it like it had a blown head gasket, he got it back home. tried to crank it again and nothing he said. I got up under and couldn't find the purple wire to the solenoid, I removed the starter and found the wire damaged, it is burnt where the wire was grounding out due to the starter crushing it. My question is, could that have caused the truck to misfire or such to lose power? if that wire is in great contact by ground, could my distributor be ruined? I will have a battery tomorrow to tinker with it.
Sep 4, 2019 at 3:31 PM
