battery replacement - Stalls
110,000 MILES • V6 • 2WD • AUTOMATIC
MREDDIE
  • 9 POSTS
Hard to start last few days, did not start today, brought battery to store for 45 minute test which failed. bought new battery and installed, quickly started then shut off, cranked again and stayed lightly on the gas and it ran normal, release gas and it quietly shut off. did this a few times with same result. now driving my wife's car and lost my "man-card" until this is solved!
Sep 23, 2019 at 6:29 AM
  • 55,694 POSTS
It sounds like the car needs to be driven for a bit so the idle can relearn. here is a guide to help us see what is going on:
https://www.2carpros.com/articles/engine-stalls-idles-too-high-low-after-dead-or-replaced-battery
This guide may help as well:
https://www.2carpros.com/articles/stall-at-idle
Sep 24, 2019 at 6:08 AM
MREDDIE
  • 9 POSTS
You're spot-on Ken, checked it that night and all is well, I'll try more patience before I bug you again! Thanks Ken!
Sep 24, 2019 at 1:32 PM
  • 55,694 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Sep 25, 2019 at 4:26 AM
CORNBREAD
I have an 2005 Equinox. I was going down the highway and it just shut off and will not start back up. I took the fuel line loose and it was not pumping fuel. After it sat overnight it started up and went about four miles then it did the same thing. I found two wires underneath the car that were broken, one red and one white. I taped them back and it ran fine idling, but it shut off when I put it in gear. Now it does nothing. I checked all the fuses and relays. I am stumped. please help
Sep 26, 2019 at 2:47 AM (Merged)
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure auto parts rent gauge. See link.
