Engine stalls
120,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
SHANE VAN WYK
Bought this car used and keys were worn out bad, turns only if lucky. Bought new ignition cylinder with key and car started and idled, all seemed fine for about two days. Then would only start and idle for about one or two seconds then cut off. I had replaced oil pressure sensors (both),coolant temperature sensor, plugs, ignition wires, because it had done this before. also the idle seemed unusually high before I replaced these. I hope I didn't leave anything out, this is my third CITI Golf, and I have never been so dumbfounded by any Golf issue. Also seems my intake pressure sensor is faulty.
Apr 21, 2019 at 5:24 AM
  • 55,710 POSTS
It sounds like you may have a vacuum leak. We should runt he codes to see what is going on. here are two guide please go over them:
and
Apr 22, 2019 at 9:44 AM
