Stalls on right turns and suddenstops
120,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
STAVO1987
The car shuts off if I turn right fast or come to a sudden stop, if I try and floor the pedal it wants to shut off as well. it does this really bad when it is cold outside and a lot less when its hot outside. i am stumped?
Dec 22, 2017 at 5:35 AM
CARADIODOC
  • 34,413 POSTS
What have you tested or tried so far, and what were the results? Was the battery recently disconnected or run drained? Do you have a scanner to view live sensor data? Have you read and recorded the diagnostic fault codes?
Dec 22, 2017 at 5:50 AM
