Stalls at idle?
2012 VOLKSWAGEN JETTA
100,000 MILES • 2WD • AUTOMATIC
JOAN1961
For a while, the car would rumble occasionally at idle, but nothing would come of it. Recently, it started stalling on its own when idling in a parking lot or drive thru lines. It's stalled 3 times now. When it does, the battery light comes on the dash, but the car starts up like there's no problem. Any ideas before I take it into the dealer?
Mar 29, 2023 at 12:04 PM
  • 110,244 POSTS
The most common cause is an engine vacuum leak. They can be caused by disconnected hoses, cracked or dry rotted hoses, or leaking gaskets or seals.
This is where I would start.
Here is a link that explains how to locate a leak and repair it:
Also, take a look through this link and let me know if it helps:
https://www.2carpros.com/articles/stall-at-idle
Mar 29, 2023 at 2:23 PM
JOAN1961
Thank you so much! I will check it out.
Mar 30, 2023 at 6:16 AM
  • 110,244 POSTS
You are very welcome. Let me know what you find or if I can help in any way.
Mar 30, 2023 at 12:09 PM
