Stalling in gear
11,500 MILES • 2.1L • 6 CYL • AUTOMATIC
ASIM.Q
hello, only in the morning when i start it and put it into drive or reverse the car stalls. I then switch of the ignition and try it again and it stalls, after a few times it then goes into gear, and then throughout the day it will run as normal. I would really appreciate your help please. thank you.
Jan 22, 2018 at 10:11 PM
  • 55,721 POSTS
This sounds like you have a torque converter clutch that is stuck and not releasing. Can you take a video of what the car is doing and upload it here in your reply? This way I can be sure also we should run the codes to see if anything comes up.
Please run this test and get back to us.
Cheers, Ken
Jan 24, 2018 at 5:04 AM
