Engine stalling
73,000 MILES • 0.9L • 4 CYL • MANUAL
LESLIE SMART
Engine keeps stalling unless chock is permanently out.
Sep 9, 2018 at 6:58 AM
  • 110,248 POSTS
If the choke has to be out, chances are you have a major vacuum leak causing too much air to enter the combustion chamber. I have to be honest, in the US, this vehicle is not available, so my information is very limited. However, I want you to check for an engine vacuum leak. Here are directions as to how that is done:
Think about it. With the choke on, you are limiting the amount of air that can enter the engine. If there is a vacuum leak, closing the choke compensates for the extra air entering the engine.
Check that and let me know what you find.
Sep 10, 2018 at 11:02 AM
