Ran for a few minutes then shut off, cranks will not restart
183,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
RHARBAUGH
My vehicle listed above has been sitting for 3 mouths. I finally got it started and it ran for a few minutes then shut off and it will not start. it cranks but will not fire.
May 30, 2020 at 10:08 AM
  • 110,248 POSTS
First, take a look through this link and see if anything helps:
Now, I suspect either there is a fuel issue or a ignition. The easiest thing to try is to see if it starts for a couple seconds and then stalls if you use starting fluid. If it starts and then stalls, then we know it is a fuel related issue. If it doesn't start, then it's likely ignition related. If it doesn't even try to start, here is a link that explains how to test for ignition spark:
If you don't feel comfortable using starting fluid, here is a link that explains how to check fuel pump pressure:
Do this and let me know what you find. Also, if you have other questions, let me know.
May 30, 2020 at 12:39 PM
