Stability light keeps coming on
100,000 MILES • 1.6L • 2WD • AUTOMATIC
LULL84
When driving in the snow it came up service stability trax and the stability light came on it then said reducing engine power I pulled over turned the car off then back on drove another 11 miles no problem. then the next time I went out no snow but still abit icy it came on another 10 or so times each time I would stop turn the car off then back on again the all of a sudden it stopped and never came back on for the rest of the day. I went out in the car two days in a row and it never came on then on the third day it came on twice, then the next two days nothing then the next time I went out in it it done it once again.
Feb 17, 2021 at 7:47 AM
  • 110,248 POSTS
First, this vehicle isn't offered in the US. However, I'll try my best to help. As far as the issue, it sounds like it could be related to a bad wheel speed sensor or the connector. What I suggest is to check where they plug in. If the wiring and connectors all look good, then test the sensor itself.
Here is a link that explains how to test the sensors. You will need a multimeter to check the sensors.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
If you find one is bad, here is a link that explains in general how one is replaced.
https://www.2carpros.com/articles/how-to-replace-an-abs-wheel-speed-sensor
I hope this helps. Let me know what you find or if you have other questions.
Take care and God Bless,
Feb 17, 2021 at 10:19 AM
