squealing noise
158,000 MILES • 2.0L • RWD • MANUAL
FRANKY JONES
when I turn my car to the left I hear a squealing noise from the passenger side wheel t sounds like friction. I have recently had two new brake pads put in the front wheels so I am stuck on what the problem could be?
Jun 23, 2016 at 7:35 AM
  • 110,248 POSTS
Does the sound change if you use the brakes?
Jun 23, 2016 at 1:40 PM
FRANKY JONES
the squealing noise stays the same, it sound like friction of metal but there new brake discs n pads so I don't understand what it could be
Jun 25, 2016 at 9:08 AM
  • 55,710 POSTS
If I can put my two cents in, I would check the dust shield on that side because it sounds like it maybe hitting the rotor as it turns.
Let us know what you find
Best, Ken
Jun 25, 2016 at 1:40 PM
  • 110,248 POSTS
If the sound changes based on speed, I would consider perhaps a wheel bearing.
Jun 25, 2016 at 1:41 PM
