Sputtering when warmed up
129,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
BOBBY MACNABB III
the truck runs fine when running cold but when it warms up it starts sputtering like it wants to stall when braking for a red light or even slowing down it sputters. the check engine light came on and the codes were for both the cam shaft position timing sensors both bank 1 and 2 being over retarded. replaced both of them but the code popped up again and still having the same issues. was hoping to fix it myself but I am running out of patients. I have heard multiple things that it could be but I just do not know
Jun 1, 2017 at 10:49 AM
  • 55,743 POSTS
The camshaft actuators depend on clean fresh oil to work correctly. Please check and change the oil as needed. Here is a guide the will show you what you are in for when doing the service.
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
If that is not the problem is could be caused by low oil pressure which will not move the camshafts as it should.
This can be caused by a clogged oil pump pick up due to lack of maintenance.
Please let us know what happens, we are interested to see what it is.
Cheers, Ken
Jun 5, 2017 at 5:30 AM
