Speedometer intermittent
550,000 MILES • 7.5L • V8 • RWD • AUTOMATIC
ESTHER SAWYER
My speedometer works sporadically. It does not seem to be associated with a certain speed. Sometimes if it is not working and I hit a bump, it will start up. Is it possible there is a loose cable or is there one? Thanks.
Jun 20, 2017 at 3:20 AM
HMAC300
  • 48,601 POSTS
these are electrically controlled so you may have a loose ground to dash. there is also a module that runs speedometer so have it scanned for codes and check ground behind left kick panel for loose.
Jun 20, 2017 at 5:15 AM
ESTHER SAWYER
Thank you!
Jun 22, 2017 at 6:03 PM
