Spark plugs gapping?
200,000 MILES
MORRISGEE
Change coils in the car listed above, now car runs rough do I need to check spark plugs gap?
Mar 31, 2023 at 3:12 PM
  • 110,248 POSTS
The gap wouldn't have changed. If you have the coils back together correctly, I would be looking for an engine vacuum leak. You may have by accident disconnected one and that will cause a rough idle.
Here is a link that explains how to locate and repair a vacuum leak:
Also, if the check engine light is staying on while the engine is running, have the computer scanned to determine why it's on. You may have gotten a faulty coil and it will let us know which cylinder to check.
joe
Mar 31, 2023 at 4:32 PM
