Smoking due to green fluid everywhere under the hood, why?
280,000 MILES • 2.2L • 4 CYL • AUTOMATIC
JENNIFER HICKS
I took my car to shop today to get a new starter replaced. so, afterwards I noticed my heat was not working, which is really odd the heat has always worked great. then as I get near my home I notice smoke coming from hood and car was pulling back a little hesitating.. when I looked under the hood I saw green fluids everywhere literally! So what's going on what could be the issue? if you could let me know what you think I would greatly appreciate it! Thanks
Feb 5, 2021 at 10:33 AM
  • 110,248 POSTS
If the fluid was green, it sounds like antifreeze. That would also explain why you had no heat. Do me a favor. Look through this link and let me know if it helps. Check radiator hoses and heater hoses. Something may have been cut or disconnected when the work was done.
https://www.2carpros.com/articles/car-is-leaking-coolant
Take care and God Bless,
Feb 5, 2021 at 12:29 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
The green fluid is engine coolant. It's possible that when the shop installed your new starter they disconnected or failed to reconnect a coolant or heater hose resulting in the leak. It's also possible that they could have damaged a coolant hose while performing this repair. I would definitely take the car back to them to inspect their work see if it is covered under their warranty. If they refuse to cover under warranty or you are not going back to them I would suggest to perform a cooling system pressure test. You do this with the car cold and engine off to prevent injury. It's basically a pump that pressurizes the cooling system and then you can visually see where the leak is coming from. Here is a tutorial showing what is involved with a cooling system pressure test:
https://www.2carpros.com/articles/radiator-pressure-test
Let us know what happens. Hope this helps and thanks for using 2CarPros.
Feb 5, 2021 at 12:33 PM
