When i press on the gas pedal smoke comes out the engine from under the drivers seat
174,000 MILES • 1.6L • 4 CYL • FWD • MANUAL
MJAZ
Hello, The car smokes when i press the gas pedal. the smoke comes out of the engine and from under my seat, it is a white smoke and smells like fuel. when the gear is in neutral it does not smoke, only when i press the gas pedal. what could be the problem? i do not want to be fooled by greedy mechanics in my country.
Oct 7, 2016 at 2:14 AM
  • 55,710 POSTS
That is a good one, do you have holes in the floorboard? Never heard of smoke coming out of the side of the car from the engine?
Oct 10, 2016 at 3:10 PM
MJAZ
Yes, I Have holes in the floorboard , think that's why its coming to the chamber , but the Car Recently Started smoking heavily "White Smoke" when i only push the gas pedal, but when it's in Neutral Nothing happens, the smoke is coming out from under the hood not the tailpipe
Oct 13, 2016 at 7:16 PM
MJAZ
Also, I Recently Showed it to a Mechanic Nearby, He told me the smoke is bluish and Need an Engine Replacement but it's clearly Not, and i tested the Oil and its still the same, I've Been told that it might be the Head gasket, Also the Car Torque is Normal , not Heavy or Light
Oct 13, 2016 at 7:20 PM
MJAZ
and Sorry i Forgot to Mention that the Car Doesn't Overheat.
Oct 13, 2016 at 7:21 PM
  • 55,710 POSTS
Yes it does sound like the head gasket is blown, here is a guide that you can follow to confirm the head gasket problem..
Please let us know what you find so it will help others.
Best, Ken
Oct 14, 2016 at 2:27 AM
