Smell of gas inside the car
1999 CHRYSLER CONCORDE
121,000 MILES • FWD • AUTOMATIC
JONE9333
We have never transported gas in a gas can or anything like that and we do not see any gas leaking down on the driveway
Nov 12, 2015 at 3:14 PM
CARADIODOC
  • CERTIFIED EXPERT
  • 34,308 POSTS
Look around the injectors. If one is wet, an o-ring has shrunk and must be replaced. Also look at the rubber fuel hoses where the steel lines on the body connect to the fuel rail on the engine. If one of those is dry-rotted and leaking, the gas can vaporize before you see wetness on the ground.
Nov 12, 2015 at 8:34 PM
