slow coolant leak
1998 SUZUKI SIDEKICK
180,000 MILES • 1.8L • 4 CYL • 4WD • AUTOMATIC
LEN23
  • 19 POSTS
Notice a small coolant leak from bottom of vent by the floor driver side. Hoping it is not the heater coil. Lots of work to rip the dash board apart no leaks around the firewall. Do smell antifreeze inside does not seam to steam the window on the defrost cycle. Not losing that much coolant any advice. Do not want leak stop plug stuff up.
Jul 6, 2017 at 3:12 PM
SATURNTECH9
  • CERTIFIED EXPERT
  • 30,869 POSTS
If there is coolant leaking inside the car out of your dash then your heater core is leaking.
Jul 6, 2017 at 9:08 PM
