Sloshing sound in dash
2012 MITSUBISHI TRITON
220,000 MILES • 2.5L • 4 CYL • TURBO • 4WD • MANUAL
ETHAN ROBB
water sloshing sound in dash. I have bled the coolant. Another thing is hot air coming out left vents but cold coming out right side of vents.
Sep 19, 2020 at 2:30 PM
  • 110,244 POSTS
If you have been using the A/C, it could be from the system. However, that doesn't explain the variation in air temperature. Which side is working properly? I ask because it sounds like a blend air door actuator is not working.
Here is a link that explains in general how one is replaced. If you tell me which side isn't working properly, I can get specifics for you.
Sep 19, 2020 at 2:38 PM
ETHAN ROBB
I have been using the A/C and the left side is hot when I have the hot turned up but the right is cold.
Sep 19, 2020 at 2:59 PM
  • 110,244 POSTS
I am so sorry. I thought this was a different model Mitsubishi. The Triton isn't offered in the US, so I have no technical information.
However, based on your description, it sounds like the blend air door actuator isn't working properly. I suspect that you have dual climate control. That means there will be one for the left side and one for the right. Since you get heat with the A/C on from the left side, I suspect that actuator needs replaced. You can remove it and see if it responds when you change the temperature.
Let me know if I can help.
Sep 19, 2020 at 3:27 PM
