Slipping out of third gear
67,000 MILES • 2.5L • 6 CYL • TURBO • 2WD • MANUAL
BENJAMIN GWYLLYM SUMMERS
Randomly slips out of third gear when engine braking, uses its clutch fluid from full to empty within a month and bites from first to second and second to third, but smooth on third to forth and fifth. Need advise seeing I have only had the car for roughly a month and a half now and don't know Skylines well enough to know if this is a common issues or otherwise, cheers.
Jul 10, 2019 at 9:02 PM
  • 55,694 POSTS
This usually means the transmission is worn out and needs to be rebuilt. Here is a video of a transmission being removed in a different car but the procedure is the same:
https://youtu.be/JpzefqEeVGE
Jul 13, 2019 at 6:32 AM
