Sinking brake pedal
200 MILES • 4.7L • V8 • 4WD • AUTOMATIC
WILLIAM MORRIS2
Sinking brake pedal I replaced master cylinder and bled all brakes. I have vacuum on the check valve to the intake of I pull the valve out of the booster the pedal does not sink but as soon as I put the valve with vacuum back into the booster the pedal will sink. I pumped the brakes to empty vac and held my foot in the pedal and started car it does not indicate bad booster. help I am stumped. please.
Dec 30, 2016 at 3:19 AM
CARADIODOC
  • 34,414 POSTS
Forget the power booster. That has absolutely nothing to do with how far the brake pedal moves; only how easily it moves.
Do you have anti-lock brakes? If you do, there is a chance air got into the chambers in the hydraulic controller. You will need a scanner to command those valves to open so the air can be bled out.
Dec 30, 2016 at 6:30 AM
  • 55,743 POSTS
Hey,
Also check the caliper slides becasue if they are sticking it will cause the caliper to back up slightly giving you a low pedal.
Here is a guide on how to service the slides.
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
Please let us know happens so it will help others.
Best, Ken
Dec 31, 2016 at 6:31 AM
