Not shifting when car is cold
172,000 MILES • 0.5L • V8 • AUTOMATIC
NANACOPE
When car is cold it does not shift, but as soon as it warms up it shifts perfectly.
Jul 25, 2018 at 1:09 AM
  • 110,248 POSTS
Based on your description, the first thing I would check is the fluid level. Automatic transmission fluid expands when it gets hot, which may be why it is working when it warms up. It is possible that a the problem is the result of a low level.
Let me know what you find as well as if the check engine light has come on.
Here is a link that describes different issues with transmissions. As you page down, you will find a section which describes no shift, soft shift. I added it thinking it may be helpful for you.
Jul 27, 2018 at 1:13 PM
