Not shifting properly
125,000 MILES • 1.3L • 4 CYL • 2WD • AUTOMATIC
FISHINGMAN08
  • 10 POSTS
Okay fine in reverse, first and second. Once up speed can go into third, but cannot start in third. Fluid level fine. What is wrong? Can we drive it as if it is a manual using tech. to shift up in gears without causing engine or transmission problems? We need to drive it thirty five miles to repair shop as towing not available.
Feb 22, 2018 at 5:12 AM
Good afternoon.
If you need to drive it to a shop, take your time and do not go over forty mph. Yes, you can manually shift it until you arrive.
Feb 22, 2018 at 6:41 AM
FISHINGMAN08
  • 10 POSTS
Should we use all the gears? And what is your guess as to what is going on, if we end up being able to use drive?
Feb 22, 2018 at 6:55 AM
It could be something in the valve body or it could be an internal failure.
if the check engine light is on, it may lead us to a control issue.
Feb 22, 2018 at 6:57 AM
FISHINGMAN08
  • 10 POSTS
So we drive at forty mph or less, only indicator light is check oil, which we knew change is due.
Feb 22, 2018 at 7:00 AM
Okay, if the check engine light is not on, then it is a mechanical issue in the transmission.
Feb 22, 2018 at 7:01 AM
FISHINGMAN08
  • 10 POSTS
That sounds backward. so if the check engine light is on, it is not the transmission, rather something else.
Feb 22, 2018 at 7:04 AM
FISHINGMAN08
  • 10 POSTS
Also, when they do the diagnostic will it actually determine mechanical or electrical?
Feb 22, 2018 at 7:06 AM
No, did not say that. if the light is on, it could be an electronic issue with a sensor, wiring or module. it could also be mechanical if the code is for the torque converter which is internal.
Feb 22, 2018 at 7:07 AM
FISHINGMAN08
  • 10 POSTS
Got it. Thanks.
Feb 22, 2018 at 7:08 AM
Yes, when the diagnostic is done they can tell if it is mechanical or electrical. they will need to do testing such as pressure tests to see if the correct pressures are working inside the transmission.
Feb 22, 2018 at 7:09 AM
You are welcome. let us know the results.
Feb 22, 2018 at 7:10 AM
FISHINGMAN08
  • 10 POSTS
I pray it is simple we are financially stretched. Thanks for the input.
Feb 22, 2018 at 7:13 AM
I understand, as we all are in the same boat.
Feb 22, 2018 at 7:29 AM
