Shaking at high speed
200,378 MILES • 4.0L • 6 CYL • AUTOMATIC
IGENIUS92
  • 205 POSTS
Hello I have a ohv EFI engine in my SUV. So here is my issue: I noticed driving the SUV it is a bit wobbly like the lug nuts were loose or something. So I checked those and they were solid. I blew a tire few day ago tires were old so I replaced the tires with brand new ones and got a computerized alignment. Ride okay at low speed but going one bumps I noticed is still a bit wobbly and at high speed about fifty mph it shakes a bit, I got a free brake inspection the guy shook the rim and said it is moving you need new bearings. I just wondered what anyone's thoughts may be to fix this shake issue. I would like to have a solid straight secure no wobble or shake kind of ride. Can anyone help?
Jul 15, 2018 at 2:20 AM
  • 110,251 POSTS
A bad wheel bearing can cause a vibration. However, there are other things too. Can you tell me, is this vehicle 4wd or only rear wheel drive? That will make a difference on what I recommend having you check.
Thanks,
Jul 16, 2018 at 12:04 PM
IGENIUS92
  • 205 POSTS
It your wheel drive I believe. It is shaky when going high speed and over bumps.
Jul 16, 2018 at 12:28 PM
  • 110,251 POSTS
Hi again. Did you mean 4wd or rear wheel drive?
Jul 16, 2018 at 1:13 PM
IGENIUS92
  • 205 POSTS
I think it is 4wd.
Jul 16, 2018 at 2:35 PM
IGENIUS92
  • 205 POSTS
Update: So I used the VIN decoder tool online and it says it is 2wd and I am pretty sure the 2wd is rear. Oh, also I have a p0136 code pop up. Any suggestions on what to do to fix this problem as well?
Jul 16, 2018 at 3:16 PM
  • 110,251 POSTS
Welcome back.
Based on the description of the vibration, yes the wheel bearings can be an issue. If that does not remedy the issue, I would suspect a bent rim or even an alignment issue. And yes, if it is 2wd, the rear wheels are the drive wheels.
Now, the code you gave me is related to an oxygen sensor (O2 sensor). This is part of the emissions system for the vehicle. Here is a link which describes how it works:
https://www.2carpros.com/articles/how-an-oxygen-sensor-works
Here is a link which describes how to test one:
https://www.2carpros.com/articles/how-to-test-an-oxygen-sensor-02-sensor
Take a look at those two links and let me know if you have other questions or need clarification on anything.
Jul 17, 2018 at 12:52 PM
