When driving down the road the van will start shaking side to side as if I tire is loose. However, when you turn the steering wheel just slightly it stops. I have jacked it up tried seeing if the front passenger tire is loose, it is not and no give. The tires are new and had the weights checked. What can this be?
Dec 10, 2018 at 8:59 PM
