Shakes when heats up
2007 SKODA OCTAVIA
112,000 MILES • 1.9L • TURBO • 2WD • MANUAL
LUIS MARIO FUSTEAC
when the car is cold it does not shake but when it heats up it starts to shake a lot! Car is driving everyday, but i do not know what that problem can be. question is why does it shake when heats up ?
Nov 26, 2016 at 4:34 AM
CARADIODOC
  • 34,366 POSTS
Shaking engine is due to a misfire. Usually that is related to worn spark plugs, and if you continue to run it that way, the unburned fuel going into the catalytic converter will overheat it and destroy it. That turns a simple tune-up into a very expensive repair. At the mileage you listed, it's way past due for a tune-up, so start with that.
Nov 27, 2016 at 9:51 AM
