Shakes when accelerating
135,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
FERNANDOA
Car shakes while pressing on the gas pedal, it shakes between thirty five to forty five mph.
Aug 16, 2018 at 10:03 PM
CARADIODOC
  • 34,413 POSTS
Please be more specific. Do you feel this in the steering wheel, or does the entire vehicle shake? If it is the entire vehicle, drive at that speed, then when the shaking starts, hold the accelerator pedal and road speed perfectly steady, then briefly tap the brake pedal with your left foot. If the shaking stops for two or three seconds, then starts up again, it is most likely related to the transmission has the wrong type of fluid in it.
If you feel this in the steering wheel, the better suspect is a worn inner CV joint. The clue is that will only cause the symptom during periods of high load/acceleration, but you will typically also feel it at lower speeds than what you described.
Aug 17, 2018 at 9:50 AM
