Service traction control
153,000 MILES • 3.6L • V6 • 4WD • AUTOMATIC
TIMOTHY HOWARD II
Got in and started it and across the bottom of dashboard it said service traction control then went out after a few seconds. No loss of power or anything. Everything still great other then that message at first start of vehicle. Any ideas why it came on? What is the usual diagnosis with it and approximately how much to fix? Going to go have vehicle coded at AutoZone for free tomorrow was just wondering what others may have had done when their's came in. Thank you
May 1, 2018 at 6:55 AM
JIS001
  • 3,412 POSTS
You would need to have the ABS system scanned for codes. A more advance scanner will be needed to perform the procedure. Autozone may or may not have the scanner for that since they usually scan for engine codes using an OBD scan tool. If you do get the codes post them on here to better guide you in the right direction.
May 1, 2018 at 2:49 PM
