My van's SE light has come on after so many times of trying to remedy the codes, from Knock Sensor to misfiring cylinder. The thing is the car runs fine, even though there is a slight rough idle. In the past two years I replaced the distributor correct a rough timing issue. I had a faulty KS code and relocated the KS and solved the code for it. I had a code for misfire for cylinder three and replaced wires and plugs which solved the code for it. One day last November my SE light came on, ran to store and codes indicated all my previous codes listed as problem. Surprisingly, the light cleared and codes disappeared. Now two months later SE light back on and store indicates same codes from back in November. My questions are: Would a professional diagnostic indicate a faulty ECM as being the culprit of my codes and light? Or just replace the ECM without the added expense of a diagnostic? Or could there be other reasons for codes and diagnostic is definitely recommended?
Jan 17, 2019 at 2:01 AM
