Serpentine belt replacement issue
186,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
LYNNR
Belt broke I replaced it ,was given the wrong one . it broke . I replaced it again battery light comes on and off . get it quite tight if so it squeals .
Aug 18, 2020 at 8:39 AM
It sounds like you may have a pulley that is locking up. Clearly the A/C compressor is the first one that we need to suspect. If the belt is too loose and the alternator is not spinning fast enough and too tight and it squeals, then a seizing pulley sounds like the reason it may be breaking.
I would remove the belt again and spin all the pulleys by hand and see if any of them are tight. If they are let us know and we need to replace that one. If not we can figure something else out but this really seems like a pulley issue.
https://www.2carpros.com/articles/car-squeaking-noise
Aug 18, 2020 at 10:18 AM
