Serpentine belt making squeaking noise
192,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
BRANDONTRUENO86
  • 35 POSTS
I changed all my belts two months ago and when i first started it the serpentine belt had a really loud startup squeak. i tightened it and it went away. However, just yesterday i started up the car and it's making that noise on startup again. Is it possible for the tension to have loosened?
Sep 25, 2019 at 1:39 PM
STEVE W.
  • 15,423 POSTS
Check the belt path very close, it is easy to get a belt off the side of a pulley and have it make a lot of noise. BTDT myself. Being a manual tensioner it is also possible that the belt has stretched some and will need to be adjusted as it does. Depends a lot on the quality of the belt for that.
Sep 25, 2019 at 2:12 PM
