Over timing retarded sensor location
225,000 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
JEANLYN1983
I am trying to find the over timing retarded sensor. Would you know where they are located?
Jan 11, 2018 at 8:01 AM
STEVE W.
  • 15,415 POSTS
There is no single sensor for the timing. it is computer controlled using the camshaft and crankshaft sensors along with engine rpm and knock sensors.
What is the issue you have or code you are seeing? That may lead to a better answer.
Jan 11, 2018 at 9:24 AM
JEANLYN1983
It is throwing codes p0011
P0016
P0018
P0021.
So both camshaft n the crankshaft but than 21 is timing over advanced. That's the one I was looking for
Jan 13, 2018 at 11:17 PM
STEVE W.
  • 15,415 POSTS
Well with those codes the problem isn't in any of the sensors, The sensors are working and telling the computer that there is a problem with the cam/crank timing. Basically the timing chains have stretched and that is changing the cam/crank timing enough to cause a problem. This is common with the newer multi chain engines because they use smaller chain. To repair it requires replacing the timing chains, tensioners and guides.
Jan 14, 2018 at 12:00 AM
