Security system
120,800 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
DEBBE JORASKIE
Does the security red light stays flashing even with the car off? key out of the ignition and the door is open or if the doors are closed and unlocked? I am having trouble if I do not drive the car for two days straight the car is dead. I have had to recharge my battery several times and I am not sure what is draining the battery. Everything is off inside the car so I am baffled to why this is happening. Any suggestions please? Thanks
Mar 28, 2017 at 2:02 PM
HMAC300
  • 48,601 POSTS
if the security light is on or stays on there is a problem with it. but yours sounds like a parasitic drain on battery. you can check it your self if you have a volt meter or test light. see link.
https://www.2carpros.com/articles/car-battery-dead-overnight
Mar 29, 2017 at 12:01 AM
