Seat belt removal
211,632 MILES • 3.8L • 6 CYL • TURBO • 2WD • AUTOMATIC
BARRYMAESMAN
How do I take the driver's front seat belt from the middle of the seat?
Oct 28, 2019 at 8:20 AM
STEVE W.
  • 15,389 POSTS
Welcome to 2CarPros. If you are talking about the buckle and strap it is bolted to the floor pan under the seat. If you slide the seal fully forward, you should see the end of the belt under the rear of the seat. Normally it will have a plastic cover that can be snapped free to reveal the Torx bolt under it. These will be either a T45 or T50 normally. There will also be a connector that goes to the light and buzzer that has to be disconnected. With it disconnected the light and buzzer will stay on if anyone sets in that seat.
Oct 28, 2019 at 12:23 PM
