Hello -
All three of those items run off the same fuse. Please look at the instrument panel fuse box fuse labeled ACC. Pull it and check it with an ohm meter. Even a good eye ball can't always tell if the fuse is good.
If the fuse is good, look in the lighter and see if there is anything stuck inside there. . .. . .anything. Make sure there is nothing in it and then see if the other things work.
If things still don't work right then disconnect the lighter plug and make sure the fuse is good and then try the radio and mirror to see if they work okay. If they do replace the lighter socket.
SPONSORED LINKS
Monday, November 17th, 2008 AT 9:22 PM
