2006 Scion xA Check Engine Code 0012 timing off
79,000 MILES • 4 CYL • FWD • AUTOMATIC
KARENP
I went to an auto store and they ran a diagnostic with their mini computer. It came up code 0012 Camshaft timing over advanced or blocked oil passage or mechanical timing fault or failed ocv pr vvt controller assembly fault. Does anyone know about how much these types of problems will cost me to have repaired or how accurate these mini computers are. I ask since my check engine light turns off after I put gas in the car and tighten the gas cap.
May 19, 2009 at 7:55 AM
DOCFIXIT
  • 18,828 POSTS
That was most likely the reason light came on. If you had all that wrong as they said you'd be call a wrecker. If no light and runs well then resume normal maintence.
May 19, 2009 at 8:18 AM
J ALAIR
What if the light does not go off and a wrecker is still not needed?
Sep 9, 2009 at 2:12 AM
