2002 Saturn Vue Airbag Question
2002 SATURN VUE
GREENFLYINGDRAGON
After the normal startup self-tests are completed, the cluster warning lights for the airbag remains illuminated, as does the service soon light. The airbag was replaced about a year ago due to an electrical problem associated with the horn switch, but there have been no other problems until now. This problem appeared to be related to cold weather (temps below +20F, as a restart after warming the car up would cancel these lights. However, they are illuminating more often now, at all temperatures and sometimes while driving. Can anyone offer an explanation regarding a cause and suggest a solution?
Jan 22, 2006 at 7:51 AM
  • CERTIFIED EXPERT
  • 53,872 POSTS
You must scan the controller to see which codes are present. Repair as needed
Feb 1, 2006 at 3:59 PM
