When I let cool it will start and run ok, then when driven until reaching running temp, it starts to act like it runs out of fuel. If I try to start it right away it will sputter for about 15-20 seconds and cut off. I had the check engine light codes taken and came up with several codes; PO706. PO122. PO133. PO341.
Autozone pulled the codes for me. And yesterday I checked the throttle position sensor and it was well in the range that it states in the Haynes book for Saturn. What can I check next?
SPONSORED LINKS
Wednesday, April 21st, 2010 AT 11:57 AM
