1997 Saturn SW1 HARD TO SHIFT IN TO GEAR
1997 SATURN SW1
104,000 MILES • 4 CYL • FWD • MANUAL
CHEVY SALES 4434
VERD TO SHIFT IN TO GEAR AND HARD TO SHIFT IN TO 2/3/4/5/ THE CLUTCH FELLS LIKE IT IS NOT DISINGAGING ALL THE WAY IT DOES NOT SLIP IF THE CAR IS AT A STAND STILL AND IN GEAR THE MOTOR DROP IN RPM THANK YUO FOR YOUR HELP I DO NOT KNOW WHAT NEEDS FIX GREAT CAR 38 MPG
May 4, 2010 at 5:16 AM
SATURNTECH9
  • 30,869 POSTS
when u push ur clutch pedal down does it have pressure all the way to the floor?or does the pedal drop freely till it gets pressure?let me know.
May 4, 2010 at 7:09 AM
CHEVY SALES 4434
it does fill fine all the way to the floor and i have pulled the matts out from the floor to make shur i am pushinf it as far as it will good that did help for a little well but now the hard to shift Thank You
May 4, 2010 at 7:41 AM
SATURNTECH9
  • 30,869 POSTS
well if ur clutch master and slave cylinder are good and ur clutch isnt fully releasing then u have a worn pressure plate with some bad fingers that doesnt allow the clutch disc to fully release all the way around it allow it to hang up.sounds like its time for a new clutch let me know how it goes.
May 4, 2010 at 8:54 AM
