1997 Saturn Station Wagon Car won't shut off
1997 SATURN STATION WAGON
TORCH1997
Engine Mechanical problem
I am trying to help a friend with her Saturn wagon. It's a 1997.When you turn the key off the car continues to run. All accessories stop working. We have found that either to pull the fuel fuse or disconnect the battery to get it to stop. By the following day the battery is dead. Any ideas why the car won't stop and why it is draining the battery?
Sep 27, 2010 at 4:26 PM
SATURNTECH9
  • 30,869 POSTS
Let me get this straight when you turn the key to the off postion the engine still run's?But the acc's turn off?Do you have a multimeter or a test light?Let me know.
Sep 27, 2010 at 4:36 PM
TORCH1997
Louie,
Thanks for your response. When the key is shut off all accessories go off. The engine continues to run. The ignition switch has been replaced. The battery drains after a few hours with the car off.
Unfortunately I do not have a meter nor test light handy. I cvan get one. What do you suggest?
Sep 27, 2010 at 5:04 PM
SATURNTECH9
  • 30,869 POSTS
You need to atleast get a test light and with the ignition in the lock position check and see if the pink wire and the orange have power you would be checking right at the ignition switch with the connector still plugged into the switch.Let me know what you find.
Sep 28, 2010 at 12:19 PM
