Removing the fuse has no affect. I tried removing each fuse in the fuse block on the center consol and none of them cut power to the door locks. I am thinking about doing the same thing with the fuses in the engine compartment in the morning.
I removed the open relay because it was very warm and left the close relay in place. The weird thing is that pressing the unlock button on the keyless entry unlocks some doors while at the same time locking others.
It seems that I must be getting a short to another live wire somewhere after the relay. My wiring schematic in the Haynes manual doesn't show anything on the wiring for the keyless entry but it should still use the same fuse.
All of the other electric systems work fine.
SPONSORED LINKS
Thursday, October 28th, 2010 AT 1:25 AM
