1998 Saturn SL2 1998 Saturn SL2, starts to die & stall
HELPMENOW01
  • 1998 SATURN SL2
  • 4 CYL
  • 97,841 MILES
When I start the car, sometimes it starts normally but on other start up's during the day, I can hear/know the engine is going to die or choke, so I have to put gas to keep idle running. This also might relate when I change gears other than neutral that the engine chokes on a few occasions. I already had the 90K maintenance 4 months ago at the dealership, with new fuel injectors and had the engine check which was fine; the problem had occurred before the maintenance which I thought was fixed. So what could be the problem?
Thursday, July 22nd, 2010 AT 5:37 AM
EDWARD.S
  • 166 POSTS
Hi, I'd Have The Computer Checked for codes first. If Any are found Write them Down, So We can help you.
Hope This Helps You,
Good Luck
Edward S.
Thursday, July 22nd, 2010 AT 5:46 AM
